hi guys. i have a 2011 RHD Touareg Hybrid with all the extras.
yesterday i was fitting new canbus LED reversing lights and i had the car on with it in reverse, hand brake on while i fitted the bulbs to ensure i got them around the right way.
left side went in with no issue. right side sparked a tiny bit and wouldnt light no matter which way i put it. i turned car off, back on again and fitted the bulbs and they both work fine (tho they still throw up an error, but i can live with that)
problem is, next time i started and rove the car i get:
1) Bend Lighting Failure - service manual
2) Drivetrain Failure - workshop
and the air suspension is locked in firm and raised mode and none of the air suspension buttons work.
I have checked all the fuses on right and left side of car, and tonight will remove passengers seat and check compressor fuse under there.
Does anyone have any idea whats possibly happened here and what i should do ? (other than just goto work shop, ill leave that till i have exhausted other options first)
thanks all from New Zealand - covid free (sorry, couldn't resist)
