Hi,
I have read several posts regarding air suspension issues on the Touareg, but haven't quite found the answers to my issue.
I recently bought my first Touareg. I'm very happy with the car, but a trip to the mountains for new years eve, made the happiness a little less happy. I live in Norway, so winters are cold and on the said trip it dropped to -16C during nighttime. Starting the car in the morning, i had the "Stop! Error running gear" message show up. Checking around a bit, it turned out the 40A fuse (F56) on drivers side (suspension compressor pump) had gone out. A bit tricky to get a new one, but I left the car running without the fuse for about 1 hour. Then i switched it off, put in the fuse, and all was good enought to get home.
It was all good for a while, and then it got cold where I live too and the problem returned. I had it at a VW-shop for repairing something else, and they had a quick look at the air suspension problem as well. They said there was no leaks, but the relay for air suspension had to be changed and they out in some condensation remover into the compressor. They also said if the problems continiued, the whole compressor would have to be changed. The quote from them was about $2500.
It has been working lately most of the time, but again the cold came and problem returned. This morning i heard the compressor working hard and loud, and some squaking sound like something had been frozen stuck and the compressor was trying to get it loose. Got the error message, checked the fuse - not broken. Took the fuse out, drove a bit back and forth in my driveway and put the fuse back in and started the car again. Worked all good.
In my non-professional mind it seems like something get's stuck when its really cold and pushes the compressor to max trying to get it loose again.
Anyone have some ideas?
