1 - 10 of 10 Posts
Hello
2011 TDI.
Looking at a set of wheels. 20x9 +48et wheels.
I do not plan on lowering it, so wanting to run a larger tire to fill the wheel wells.
Any input on sizes to consider? Would love pictures of your setups also
275/45/20 seems too small IMO.
There are already lots of threads on tire sizes as this subject comes up quite often.
Use the Search function to find them.
There are already lots of threads on tire sizes as this subject comes up quite often. Use the Search function to find them.
^he's right.
get a wider aftermarket wheel. 9" wide wheel limits your tire width. and my guess is youre going to need spacers.
though i do think there's an OE benz tire size, 285 x 50 x 20 that could work, just don't think anyone has tested it
OEM 20s are 57mm offset? You're looking at 48mm, so: less distance from the mounting surface to the center of the wheel, so: it should stick out more than the OEM 20" setup. I don't think 11mm is enough to rub on the fender, so you should be good. Do a test fit and report back!
1 - 10 of 10 Posts
