Now that it's started to get cold here, I've run into some very strange issues with the cabin heat. Before I take it to the shop I thought I'd try here and see if y'all had ideas.
Vehicle: 2011 Touareg Hybrid (not, Climatronic dual zone system, No Dynaudio. Mileage 101,000. Previous owner had both of the water pumps replaced at some point. (the electric aux one was replaced twice).
Vehicle cabin heat functions continuously only at highway speeds (60 MPH+) except in the following circumstances:
If Vehicle is started from COLD condition: Cabin heat functions properly until engine reaches operating temperature. Cabin heat is initially felt as coolant temp gauge comes off peg (120F). Cabin heat performs optimally until temp gauge reaches 200F. At that point, cabin heat ceases. Fans continue operating normally but only cold air from both floor and dash vents. If driving continuously at highway speed (60+mph), cabin heat returns in 3-5min.
If vehicle is operated at low speeds cabin heat is not functional unless engine revolutions exceed 2,000RPM. Similar situation evident with vehicle stopped and transmission in Park or Neutral. Cabin heat functional only when revs are held above 2,000RPM.
If vehicle is started from WARM or OPERATING TEMPERATURE condition, cabin heat may operate briefly (~60sec) before returning to blowing cold air until one of the above conditions is met (60+MPH or engine revs over 2000rpm).
Residual Cabin Heat (REST) feature only produces heat momentarily (60sec) and only if Cabin Heat was functioning normally when vehicle was shut off. If vents were blowing cold air at shut off, REST feature does not produce heat at all. I don't know how loud the auxiliary coolant pump is, but I do not hear anything (no clicks, no whirring, nothing) from the driver's side wheelwell.
Cabin Heat will not function continuously when vehicle is operating in Hybrid/Electric mode and the engine is not running.
Coolant is clean and clear. No sign of oil or excess pressure. I have heard a swishing/water rushing noise behind the driver's dash a few times mainly at startup. Engine Temp does not ever rise above operating temp - even in ambient temps above 98F.
This happens with the system in Auto mode as well as if I manually set the temp and fan speed. Raising the temp setting just causes it to blow more cold air.
Things I've tried: I thought this might be air in the system so I started with vehicle cold and loosened the resevoir cap and let it idle to operating temp. Or at least I tried that because the dang (wonderful) machine doesn't want to stay running once the battery is charged. I had to hold the gas pedal down to keep the revs up at least above 1200, so I couldn't really watch to see how much air i got out of the circulating line. I thought it fixed it, but it was a warm day and now the problem is back again.
