Well…! It’s broken again!
Had a fault on the EPB system
Tried disconnecting battery and waiting a few minutes, before reconnecting battery. Same problem! EPB fault, red flashing on dash. Cannot release EPB to drive away. Had to get a flatbed to take it home.
next problem was to drag it from driveway into garage to work on it!
Used crazy carpets and wheel dollies to pull it in the garage.
Plugged in VCDS and this was the codes in module 53.
I am going to try and remove the EPB electric motors and manual turn the screw to open the brake shoes. Anyone done this before?
I can’t do a basic setting so if I can get the drive mechanism to retract. I’ll start from scratch with the basic setting and see if the module wants to play…!
Anyone have any other suggestions?
