1 - 12 of 12 Posts
I have one available now, and 1 coming in late next week.
If you want a spare to be able to swap in and out this is for you :)
$650 shipped in North America
Removal install easy for someone still looking to take advantage of factory warranty if need be?
If so, I’m in.
Reverts the shifting patterns back to pre-fix but is based on fixed software so it looks to VAG to be exactly the same.
Give you back the original shifting patterns and engine braking, etc.
Discussion Starter #8
If so, I’m in.
Yes it' not too bad, search for speed engineering, I posted a video from them that shows where it is located.
It is mounted upside down underneath the passenger seat. It is possible to remove with the seat in place, but it is easier if you can remove it.
There are two tabs about mid way back that you push away from the unit to drop it down.
The you will see the slidelock connector that you slide away from the unit to release the connector.
I'll send you a message on how to proceed with payment,..
1 - 12 of 12 Posts
