1 - 20 of 25 Posts
So I keep getting the airbag light coming on on my 2010 TDI.
I keep clearing it and it comes back. I also have some random codes never seen before.
Tuesday,01,March,2016,15:20:31:02226
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
VIN: WVGFK7A92AD000405 License Plate: 7PET031
Mileage: 135650km-84289mi Repair Order: 3012016
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2E 37 46 47 55 56 65 68 69
6C 6D 6E 76 77
VIN: WVGFK7A92AD000405 Mileage: 135650km-84289miles
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CAT) Labels: 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 T HW: 7L0 907 401 K
Component: 3.0TDI EDC17G004AG 0090
Revision: 33H02--- Serial number: VWX3Z0I6866626
Coding: 0421002A590F0968
Shop #: WSC 20108 444 11736
VCID: 3C77DA087C6315DE6D-50E8
1 Fault Found:
008704 - NOx Sensor 1 Bank 1
P2200 - 003 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 135527 km
Time Indication: 0
Date: 2016.02.28
Time: 18:23:26
Freeze Frame:
RPM: 2205 /min
Speed: 110.9 km/h
Inj. Quantity: 0.0 mg/str
Temperature: 129.8°C
Temperature: 24.3°C
Absolute Pres.: 877.2 mbar
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 LD HW: 09D 927 750 JK
Component: AL 750 6A 1569
Revision: 00H75000 Serial number:
Coding: 0004456
Shop #: WSC 31414 790 00001
VCID: 7BF5191439EDD2E624-5122
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0004354
VCID: 4683B8E035AF5F0E0B-8012
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 C HW: 7L0 909 137 C
Component: 2G Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0I6866626
Coding: 0147688
VCID: 3365F134563DDAA6BC-8066
Component: ELV XXXX
Part No: 7L6 907 040 AL
Component: CLIMAtronic R/L 4537
Coding: 0023030
VCID: 7AFB1C1031D7EBEE3F-802E
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2004
Revision: -0004--- Serial number: --------------
Coding: 220008002F00BC000000000000000000
VCID: 000F6EF8570BB13E71-8054
1 Fault Found:
02252 - Generator
003 - Mechanical Failure - Intermittent
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 A HW: 7L0 959 655 A
Component: J234__0D VW8T 0270
Revision: 92013027 Serial number: 003C6000CVM0
Coding: 0012356
VCID: 3B75D9147E6D12E664-806E
Subsystem 1 - Part No: 7L0 959 339 E
Component: BF-Gewichtsens. 007 0009
Subsystem 2 - Serial number: 4J1HJ
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11101001
Fault Priority: 2
Fault Frequency: 47
Reset counter: 255
Mileage: 133973 km
Time Indication: 0
Date: 2016.01.30
Time: 14:22:29
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
VCID: 428BA4F01987632E27-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 990 P HW: 7L6 920 990 P
Component: J285 KOMBI-INST. 9833
Revision: KHH06V43
Coding: 0001201
VCID: 4683B8E031AF5F0E0B-8012
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 990 P
Component: J533 GW-K-CAN TP20 9833
Coding: 77E2F7DBCB846002
VCID: 70EF3E3863ABA1BE81-8024
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
Shop #: WSC 00000 000 00000
VCID: 01096BFC5B01B8367E-5122
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667454194
Coding: 020000
VCID: 2643186051EFBF0E2B-8072
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 684 B HW: 7L6 035 684 B
Component: RNS-MID H02 0362
Revision: AB001001 Serial number: VWZ6Z7J8184111
Coding: 000100000100002600
VCID: 3561CF2C9C49C49692-8060
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 254
Reset counter: 206
Mileage: 131960 km
Time Indication: 0
Date: 2016.01.20
Time: 11:31:45
Part No: 7L6 959 933 A
Component: 4M HSG 0601
Coding: 0000085
VCID: 408FAEF8108B713E31-4AEA
Subsystem 1 - Part No: 7L0 959 701 P
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 P
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 456 C HW: 7L6 035 456 C
Component: 08K Audioverst. 0001
Revision: 00001000 Serial number: 00000000217183
VCID: 3365F134523DDAA6BC-8066
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 1290435
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000019
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 206
Mileage: 131960 km
Time Indication: 0
Date: 2016.01.20
Time: 11:31:45
Address 65: Tire Pressure Labels: 7L6-907-273.lbl
Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
Component: J0502 RDK 0006
Revision: 00004006 Serial number: 00000700014803
Coding: 0040008D8D0000000000000000
VCID: 3A7BDC1071572BEE7F-806E
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 3979C31C705120F676-806C
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 070709 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0080
Revision: 4A008002 Serial number: 00000119303297
Coding: 0016386
VCID: 3F8DAD046A750EC648-806A
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 B HW: 7L6 907 441 B
Component: J772__Rearview 0033
Revision: 00H13000 Serial number: PA8 J960224
Coding: 0110001
VCID: 3467F2285733DD9EA5-8060
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------046387
Coding: 0122110
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No SW: 7L6 919 044 AD HW: 7L6 919 044 AD
Component: J702 Dachdisplay 0401
Revision: 1030006S Serial number: 00000000123138
VCID: 79F9031C30D1E0F636-802C
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
VCID: 3979C31C745120F676-806C
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
Component: FSE_2P8x H35 0170
Revision: 00000000 Serial number: 00000005071860
Coding: 0012077
VCID: 387FC6184B5B39FE89-806C
End-------------------------(Elapsed Time: 04:02)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 19: DTCs cleared
Address 22: DTCs cleared
Address 2E: DTCs cleared
Address 37: DTCs cleared
Address 46: DTCs cleared
Address 65: DTCs cleared
The airbag light might well be the yellow connector under the seat losing contact.
If it is then it is a well known Touareg fault as the wiring was too short and, as the seat ages, or some fat lard-arse sits on it - the overweight car cleaner at my local VW dealer in my case! - the connector loses connection.
Dealers were given a short extension loom.
Owners can fix it themselves by hard wiring in an extension of their own.
Disconnect the battery.
Leave the car for half an hour at least.
Then work on the connector.
Reconnect the battery.
Clear the fault code.
I read about the short wiring. I will check this out. Is there a repair wire part number they use? I have long legs so I have to put the seat back a bit more than my wife. None of us are lard asses thank you very much! I do most of my own work so not many fat car ash guys cleaning my car. ;)
Bad alternator not sure about that! Car 84K miles on and never had issues with dimming lights, no start dead battery nada. But maybe.
O2 sensor, not sure either. No CEL for any of these issues and I just passed smog a month ago not that that would tell me much unless it completely failed.
Thanks all
I have the airbag light 'permanently' "on" on my '04 but I thought they fixed the issue for cars as late as the OP' '10?
No, looks like they possibly have not learned from their mistakes.
Are we talking about the passenger airbag? My passenger airbag light in the center console needed to be replaced recently as I was getting an airbag error. I also have a 2010.
I believe the short loom was fixed on the T2's. That was a T1 issue.
Discussion Starter #8
I guess so. 01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
I mean it triggers the dummy light in the cluster. So maybe there is a problem with that loom.
Ok. well I will have to check into it.
thanks
It reads as a fault to the light. The thing Nooby was talking about was a T1 issue, not a T2 thing. You could have a faulty weight sensor in the seat or the light it's self is just bad. It is telling there is a ground issue.
If you are clearing the faults and they come back those things causing the faults need to be fixed for the error to go away permanently. It is telling you that there is a bad NOX sensor and is telling you which one it is. Fix what is causing the faults and they will go away.
Reactions: alfissimo
Multiple v10tdi owner
(3)2004 V10tdi’s
I had the same problem on both of my 04's. The fix for me was to remove the two repair wires Vw added on the TSB and solder in a section of wire to replace their crimp splices...
Fix it ASAP.
Whilst it's on, some or all of the airbags will not work in an accident.
Yes, later cars should have been fixed but, from memory, the fault code is the one I saw a couple of times [which is why I suggested this might be the problem] which I got fixed in an less than an hour minutes by airbagman [a specialist UK firm who come to your home or business] wiring in an extension on both front seats.
Cost me the equivalent of $150.
008704 - NOx Sensor 1 Bank 1 is a simple fix for under $500. Sensor is the one with the control module mounted on the drivers side engine compartment. G295
Discussion Starter #13
I cleared the code fro the airbag light for pass. side, it came right back on. What is the behavior of the bulb/light (pass)? Mine flickers a bit when I sit in the seat and then finally goes out after 20-30 secs of me sitting in seat.
Sounds like the weight sensor could be bad. But it is also telling you that you have a ground issue with the light too. Try checking that out.
"1 Fault Found:
009 - Open or Short to Ground - MIL ON"
I had a frayed wire underneath the passenger seat coming off one of the harnesses. It seems to have been pinched against the molded shelf at the front of the seat. Move the seat to the highest position and check to see if any wires are missing their sheathing.
Any resolution to this? I also have a '10 TDi with the same passenger side airbag issue. Or its atleast similar - Getting the codes from the dealer today but they wanted $900+ to replace the side passenger airbag which is ridiculous if this has a simpler fix like the older models with the short wire issue. Mine went off after a 10hr road trip with my brother in the passenger side who is quite a large person and also repeatedly jammed the seat back all the way to ensure he had the maximum leg room. So it could be the short wire cause or I suppose the weight sensor. But not sure how that breaks an airbag??
AndrewT
If the dealer has given you the codes, they should also have cleared them which should have reset the airbag light.
Tell your brother to walk, and then just drive the car to see if the light comes back on. If it doesn't tell him he can only sit in the back in future!
My money is on the big yellow connector and short wires.
Do you mean "short wires" as in not long enough or in the electrical sense?
I thought the short length wiring loom was a T1 issue only. It was lengthened in T2's no?
1 - 20 of 25 Posts
