Update
been busy on stripping down the front, I finally have everything disconnected on top and around the engine in the bay
Wiper removal as usual was a pain in the ass lol
So far everything is been going smooth
I put all my screws in ziploc bags and duck taped to part and then place them in big plastic tubs till i have to put it back on
if any of you have tips on how to keep screws and parts removed safe and organized please share, again I have zero mechanic skills only been working in my Treg and builded Legos till I was 15 years old
As I’m stripping down I made a cart at FCP Euro, ECS tunning, AutoHausAZ and Blauparts on all parts and tools I need - if any of you have ideas or wana share knowledge on what to replace while engine is out please share so I can order parts
I have the following:
Oil pressure switch - 06A919081J - 1 - while I do a carbon clean - FCP Euro $25.99ea
Camshaft plugs - 078103113E - 4 - will replace both banks - FCP Euro $13.95ea
Hydraulic Lash Adjuster - 022109423D - 2 - FCP Euro $6.29ea - this is what made me do this job
Camshaft Seal - 06E109345A - 4 - ill replace all 4 of them since i’ll replace the camshaft plugs and gaskets - FCP Euro $11.59ea
Transmission Mount Kit - OEM Corteco 80004521KT1
Comes with 2 bolts - FCP Euro $39.07
Engine Mount Kit - OEM Corteco KIT-538735 - 2 engine mounts with hardware - FCP Euro $222.08
Crankshaft Seal - OEM Corteco 079103051G -1 - $9.19ea
Oil cooler O rings / gasket - 079103121AD - 2 - FCP Euro $4.49
Rocker Arm - 06E109417P - 2 - FCP Euro $15.99ea - this is what made me this job- broken rocker arm
O ring - WHT002789 - 2 - FCP Euro $0.59ea - o ring on the camshaft solenoid
O ring - N90713203 - 2 - FCP Euro $1.79eac - o ring coolant pipe inside timing cover o ring closer to camshaft - inner o ring on coolant pipe
O ring - 91065802 - 2 - FCP Euro $2.39ea - o ring on coolant piper inside timing cover close to cover
or outer o ring on coolant pipe
Camshaft Sproket Bolt - N91042802 - 4 - FCP Euro $3.99ea
Pentosin CHF202 Fluid - 00004330574 - 2 - FCP Euro $18.59ea - 1 litter per bottle - ordered 2 not sure how much I need
Loctite Sealant - 00004320435 - 1 - AutohausAZ $19.69 - need for the sealing retainer frame that sits under valve cover on top of head
Valley Pan Gasket - 079103161J -1 - AutohausAZ $6.19 - when I do carbon cleaning
Pentosin Antifreeze G13 - G013A8JM15L - 1- AutohausAZ $43.99ea 5L bottle - not sure how much I need …. Also have other VAG cars
Pentosin Antifreeze G13 - G013A8JM1- 1 - AutohausAZ $15.19ea 1.5L bottle - not sure how much I need
Left Inner Valve Cover Gasket - 079103649C - 1- AutohausAZ $17.89ea - this gasket sits under the retaining frame and seals spark plugs, use loctite to seal rest of outside retaining frame
Right inner Valve Cover Gasket - 079103650C - 1 - AutohausAZ $17.89ea - this gasket sits under the retaining frame and seals spark plugs, use loctite to seal rest of outside retaining frame
Manifold Gaskets - 079133074B - 2 - AutohausAZ $17.59ea
already bought engine oil, spark plugs, coils, valve cover gaskets
If there is anything else I’m missing please add on, thank you to all responding and guiding me
found a 4 foot metal industrial push cart $75, I’ll put two 5 and half feet 4x4 wood blocks under to drop subframe on top
I took lots of pictures, this is just a few
Look at oil by crank
Hoping to pull engine out and place next to Treg and work on it, very nice to have lifted Treg and placed on dolly wheels to give me enough space for disconnecting exhaust, tranny connection, steering
I had to get creative my garage and parts I took off
This yellow and purple o rings comes off the A-C condenser up front - I looked to see if I can purchase new o rings but no luck so far
Everything on top in engine bay disconnected - was not that difficult just lots of fluid catching lol
