1 - 11 of 11 Posts
G’day, does anyone know where you can purchase Adblue for V10 in Australia, other than VW dealers?
Werner
Discussion Starter #2
Sorry, obviously 2008, not 2018 - I wish?
Are you sure it is ad-blu you need?
I ask because a number of V10s used something called Eolys fluid.
The fluid was intended to last :sick:100,000 miles or it had to be drained and changed after 5 years.
It is nasty stuff so any waste had to be properly disposed of.
From memory the Eolys fluid filler is under a rubber flap by the diesel tank filler cap.
Buying Eolys fluid from the dealer is very expensive and a refill is several $100s but other makes such as Peugeot also used it and their Eolys fluid is a lot cheaper.
I can't remember the tank capacity but a search on here should bring up old threads.
However if it is definitely ad-blu then any ad-blu from any supplier is fine - just make sure the use-by date is good.
Yep, it’s that stuff you talk about, with filler located under rubber around fuel tank filler. The independent guy I take it for service, last time ordered it from either Peugeot or Renault. Was tricked from over east, as cannot be on plane.
Also, I think tank capacity is 4 litres
Yep I realise it’s not the “normal” adblue, but that’s the name that gets used generally- thanks for passing on the correct terminology
Renault, Peugeot, Citroën and maybe others used it.
From memory a VW dealer Eolys refill headed toward $1,000! It was a cost the first owners of V10s probably never discovered but came as a nasty surprise to subsequent owners.
I remember someone on here filled their Eolys tank with ad-blue in error and then had to drain the system pronto!
Hi,
do somebody know a difference between
ISO 22241 and ISO 22241-1 Adblue standard?
Can be this two mixed?
Werner
regards
Drag
Discussion Starter #11
Thanks Drag, I actually contacted them yesterday. $91 per litre, but almost half that if the independent mechanic wants to keep some in stock?
1 - 11 of 11 Posts
