1 - 8 of 8 Posts
Hi guys i was wondering if u can help me with the part numbers for front and rear brake pads of my touareg. my touareg is 7L60e3 Touareg V6 FSI 206KW
i checked online it seems to me that there are several types available.
there are 2 types of pads. it depends on what type of calipers you have, my guessing is you have smaller one with 4 pistons and 2 pins holding the front and rear pads, in that case you need front # 7L6698151J and rear # 7L6698451B
in case im wrong and your touareg have bigger calipers with 6 pistons in front and 4 at the rear you gonna need this part numbers front #7L0698151S and rear # 7L0698451H hope this helps :) kind regards, Nikoloz
P.s you need to put you question in the thread title so that it will be more understandable for everyone :)
welcome, just double check the calipers if you have 2 pins in front holding the pads in this case you have 4 pistons and you need smaller pads, you have all the part numbers you need :) good luck :)
Discussion Starter · #8 ·
here is the update: i needed these sets for my car:
front brake 7L6698151J
rear brake 7L0698451H;
1 - 8 of 8 Posts
