Can anyone help me locate the VVT solenoid on my 2008 V6 please? I need to check to see if it needs to be cleaned or replaced. Any diagrams or photos will help. Thank you.
Check engine code P0014. High RPM while idling after being driven for a little bit. It wants to jump while stopping. It's getting difficult to drive.What types of issues are you having? Codes? I went through a timing chain “stretch” issue last year that wasn’t resolved until the exhaust cam solenoid was replaced. Supposed to be an engine out thing, but my independent euro shop was able to replace it without pulling the engine.
That sounds awfully similar to the issue I ran into with the timing chain. This is a somewhat common issue as these age. My 2007 was at 129,000 miles when it had this issue. I'm no diagnostician, so someone else might chime in with other potential causes.Check engine code P0014. High RPM while idling after being driven for a little bit. It wants to jump while stopping. It's getting difficult to drive.
