1 - 8 of 8 Posts
My 2004 Touareg V8 is now gone and I have just bought a 2008 T2 V8 with 62k miles. I kept looking at other vehicles and came back to my Treg and bought another one :)
I'm not as familiar with the T2 so any advice on any 60k maintenance appreciated. Its the FSI motor and I understand this has a timing chain so no 80k timing belt. My initial thoughts were
Spark Plugs
Engine air filter change
Pollen filter
Not sure on trans and diff as it has no tow hitch so the drive train shouldn't have seen too much strain
Rotors look re-surfaced so someone cheaped out - plan to replace these with Brembo OEM's - do you know if they're the same size from the T1?
Also it comes with 19 inch rims and 275 45 19 Yokohama Advan's and I have a set of 255 55 18 Pirelli Scorpion snows - can I used these for the winter - are they the same rolling circumference
Thanks in advance
John
18s are fine.
Definitely change the ATF, and the transfer box and front and rear diff fluids.
2008 4.2L FSI 60,000 maintence
change oil and replace filter
replace spark plugs
airbag system: visual check every 12 months regardless of mileage
headlights: check and adjust if necessary
W/W and headlight fluid: check level and add if necessary
Automatic shift lock: check operation including park/neutral position switch
brake system: check damage/leaks, fluid level, check brake pad thickness
battery: check
Engine: check for leaks
cooling system:check coolant level and add if necessary
automatic trans: check for leaks
tires: check tread depth and pressure and adjust if necessary
wheels: rotate
driveshaft: check boots
Engine OBD- check DTC memory; purge if necessay
door arresters- lubricate
exterior lights: check front and rear
255/55R18's will work great for snow tires or all season
page 2
exhaust system: check for damage and leaks
sunroof frame: clean and lubricate
Road test: check kickdown, braking,steering, heating and ventilation, air conditioning, power accessories and electrical systems
front axle: check dust seals on ball joints, check tie rods
Thanks guys
Thinking ahead as I'll be asking to have the plugs done
Did the T2 have the same TSB on the coil packs as I know the dealer did those for me on my T1 for free?
John
VW 2008 Maintenance Service Circular is attached, as well a the maintenance section from eRWin..
Stuart...
Thanks Stuart
I also had a call from the dealer (Dodge/Chrysler so not a VW specialist) as I could smell gas on the test drive...he told me its a crack in the plastic on the fuel pump and he's replacing it so can't pick up until Monday...anyone heard of this as looking at fuel pump replacement its under the rear seat so wondering how it would have cracked or do they fail over time...? I also read it has 2 fuel pumps so checking Monday with the dealer if its just one or both...
Discussion Starter #8
Thanks for all the info - Big service done at the dealer ($1200 as needed a new vacuum hose) but the car feels and drives great. Can't wait to test the towing out later this week. Only remaining issue is the rear window won't budge or close fully....so I might have the dreaded window regulator problem....going to the dealer tomorrow for diagnosis...and probably another bill...its all worth it though as I love my Treg!
1 - 8 of 8 Posts
