1 - 13 of 13 Posts
I started the Treg today & the Nav Screen is not working. Radio is fine, I can select stations by rembering which button is what station. The backlight is on, I checked the fuses. Is this common, is it repairable? i'm afraid to pull fuses as I don't know if will lose its presets or worse ask for code.
Can anyone tell me if I will lose the radio station presets or lock up the unit if I pull the fuses?
Supreme Member
It's worth a try either way, though I believe it's not going to change anything.
Try it, and let us know.
What's the worst that can happen? Do you not have the radio code in the manual?
Sorry, but how can you enter the code without the display?
Discussion Starter #10
Ten minutes later I stopped for fuel and it died again. Later in the day while putting into park it started to display but flickering. I tried to attach a .mov video but its in valid. At the end of day the display looked like this.
Discussion Starter #11
Last night I pulled the fuses, no change. Radio still works. I pulled the unit and removed the display head, could go no farther as it needs a torx bit smaller than #8 which I will look for today.
Discussion Starter #13
I removed the display head & reseated the connectors & ribbon cables, no change. I ordered a display off ebay Sharp 6.5" LQ065T5AR01 TFT Display VW MFD2 for $150 delivered. New display has been working for several days now. you will need torx bits #20 #8 & #6 for the job.
1 - 13 of 13 Posts
