Hi,
I'm having issues with a 2007 V6 TDI. The car is originally equipped with two batteries.
The car drove just fine, was parked for ~8 hours in cold weather and could subsequently not start. It cranked but didn't start. Several attempts to boost using starter cables from an Toyota RAV4 + an additional battery didn't solve the problem. Car was flatbedded to the mechanic.
The car was charged with both batteries mounted using the posts under the bonnet. VCDS showed a hell a lot of errors due to low voltage. After clearing these (several attempts) they've all disappeared.
The car seems to crank just fine but just doesn't start. Thinks that have been checked:
1. Belt to high pressure fuel pump intact and spins when cranking.
2. Engine RPM (G28-sensor) shows between 147-168 rpm when cranking.
3. Rail pressure is dead zero (0) when cranking.
Especially regarding
2): Could anyone confirm whether there's a lower limit of engine crank speed before the ECU initiates a start?
I found the following on another site:
V6 TDI battling to start in the morning - 4x4 Community Forum
The cranking speed needs to be at least 280rpm on the v6 TDI
3): Is it correct pressure should first be built after sufficient RPM has been reached? Is there some kind of magnetic clutch on the pump?
Any input would be very much appreciated.
