Hi Fellow Touareg owners,
I need some help diagnosing my current starting problem. Most of the time my car will start, but occasionally it will crank for about 2 seconds and then stops cranking for no apparent reason. I have replaced the battery and the fuel filter, but so far this hasn't made a difference. There are no warning lights when the problem occurs, and the speed of the cranking is normal, but it just won't crank for more than 2 seconds. I can then go for another week with normal starting, and then it will suddenly just stop cranking properly.
I have noticed that when the engine is starting from cold, it doesn't seem to have the problem. The problem seems to occur generally when the engine is still warm.
Has anyone had a similar problem, and what was the solution?
Regards
Dave
Regards
Dave
