1 - 4 of 4 Posts
2007 3.0 tdi electrics
Hi Guys, first post on here. I have above vehicle but the wiper stalk and the fuel, battery and temp gauge do not work. The light on the dash goes out when the bonnet is closed so prob isn't the bonnet sensor. The rear wiper work just fine. I wonder if I am missing a relay as this car was flood damaged a few years ago and someone might not have replaced all of the relays? If I look under the dash on right hand side the relay tray has plenty of spaces and only two or three relays in it
Many thanks in advance
Koz
2015 R Line V8
Hi Koz,
Welcome.
Have you just purchased this car? Warranty? Has someone done a VCDS scan to check the vehicle electronics?
What city/area are you?
Hi Steve have owned it a while and only used it to play around the tar in until winter. Had it scanned a while ago at local garage buy not VW scanner
MoT now run out and they say it would t pass without wipers working
Should the relay tray under the sash be full as there are three spaces with dust around them which appear to have had relays in in the past I feel?
I thought it strange that only one side of the dash instruments were affected
(The right hand side)
Fuel batt and temp and fog lights
1 - 4 of 4 Posts
