2006 VW Touareg V10 TDI SOLD $14,500
Message
4.7K views 20 replies 12 participants last post by  a1cmaw
$17,000.00
Check price
Bellevue, Washington
16 years one non-smoker owner, meticulously clean, 505.01 oil changed every 5K miles, no leaks, no dings, no rust, PPF on leading surfaces, 120K miles, have all service documentation performed and up to date, original window sticker over $70K, no warning lights or CEL, completely unmodified EGR & DPF, offroad gray with teak leather, loaded with 37 options incl: center & rear lock diff, Nav/Sirius/6 disc CD, air suspension, bi-Xenon lights, sunroof, roof rack, tow hitch, Gorilla Gear floor mats, 2 keys, $17,000.
Clean VCDS, except non-functioning rear seat DVD player.
This is a tank that gets 24MPG and cruise 500+ miles at 80MPH.
Replaced front & rear batteries, brakes & rotors, turbos, tandem pumps, carrier bearing prop shaft, intake manifold flaps.
This has been a great rig, but new Cayenne is on the way!
Monster out of it's cage! While replacing tandem fuel pumps lots of WYIT like replacing DPF, turbos, oil filter housing, prop shaft & carrier bearing, glow plugs & housings, intake flap motor, cleaning throttle bodies & EGR valves. Did it all because I was really intending to keep this forever.
WTF is a tandem fuel pump?
If it's a fuel pump, its a fuel pump.
If it's a fuel and vacuum pump, it's a tandem pump.
Look up the definition of tandem!
Also, there's one of each.... not two of either, not even the ones you're making up as being a thing.
Hello my name is Arsh. I’m interested in your touareg that is up for sale. I’m from Oregon and would definitely like to come up there and check it out. Thank you
Nice clean Treg.
Best of luck with the sale.
Nice clean Treg.
Wow Nice V10!
Many things taken cared
V10 still for sale. Sorry for delay replying as I have new Cayenne to keep me busy, and the V10 has been sitting on trickle charge. Attached VCDS shows Address 46 intermittent complaints I think is due to DVD intermittent ground faults. All keyless entry (no push to start in 2006) works. More interior pics attached:
Monday,15,July,2024,13:53:31:35794
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.5.0.0 (x64) HEX-NET2 CB: 0.4643.5
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVGPT77L96D059172 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L96D059172 Mileage: 196260km-121950miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG001AGMÂŞ9805
Revision: --H02--- Serial number: VWZ3Z0E6432763
Coding: 0060575
Shop #: WSC 23328 444 54029
VCID: 6194CA75BD51172238D-5160
VINID: 9E65E09071DC246500149047080B427904
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 DP HW: 09D 927 750 DP
Component: AL 750 6A 0856
Revision: 00H37000 Serial number:
Coding: 0004216
Shop #: WSC 31414 000 00000
VCID: 7F506C0D2BE5C1D22E9-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
VCID: 3D2C5605616913C27C5-5160
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 A HW: 5WK 485 02
Component: 29 Kessy 6700
Revision: 67005715 Serial number: VWZ3Z0E6432763
Coding: 0147688
VCID: 31347A35AD31E7A2E8D-5160
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77A0842D03D5F992669-5160
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 T
Component: CLIMAtronic 2+2 4222
Coding: 0020030
VCID: 45DC3EE509B95B02245-5160
Subsystem 1 - Part No: 7L6 907 049 E
Component: CLIMAtronic FOND 0400
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3002
Coding: 0111839
VCID: 47C034ED33B54912D69-5160
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG001AGSÂŞ9805
Coding: 0060575
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0007519;
Coding: 0012341
VCID: 280297519EEBA66A3F3-5160
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010032
VCID: 44DA23E10283620A33B-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 R
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0007231
VCID: 48C237D13EAB466ADF3-5160
Address 18: Aux. Heat Labels: 7L6-819-008.clb
Part No: 7L6 815 071 D
Component: Standheizung E1MAC
Coding: 0000100
VCID: 3338703D572DD5B29A1-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B2BF3166BBAEAAA73-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 0D4CC6C51149E3422C5-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000003
VCID: 669ED969547F701ACDF-5160
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 363E4929445FC09ABDF-5160
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0703
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0047
Coding: 0000101
VCID: 50F21FB1C6FB8EAA873-5160
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000003
VCID: 6780D46D53756912F69-5160
Address 46: Central Conv. Labels: 7L0-959-933.clb
Part No: 7L0 959 933 J
Component: HSG 5115
Coding: 0000085
VCID: 43D820FD078D65320A1-4B00
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 47: Sound System Labels:
VCID: 55FCEEA5FC09EB82545-5160
Note: Excessive Comm Errors
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 E
Component: Radio 0047
Coding: 0014062
VCID: 353C4E255959CB82B45-5160
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C2A5B017A731ACA4BB-5160
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 31414
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J610088
Coding: 0000101
VCID: 72B6B53968B79CBA517-5160
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 3924421575412FE250D-5160
End----------(Elapsed Time: 07:44, VBatt start/end: 13.3V/13.4V)-----------
Thanks for the response and additional info/pics!
I was recently picked up in the exact year/make/model as your Touareg (Black exterior and interior) and brand new to the reality of what this car really is!
My girlfriend's mentor and old colleague has had his 2006 w/ 220K miles since 2007, after buying it from the original owner and he has nothing but good things to say about it.
I'm located in Phoenix, Arizona so unfortunately I'm not local to swing by and look at the vehicle...but definitely interested.
Also, I would need to find an auto loan with a good interest rate and hoping you would be open to negotiating the price.
Do you have additional contact info: phone number/email/social media anywhere we can communicate more easily?
Cheers!
Michael
You can contact me at DELETED PHONE #
or email: DELETED EMAIL
Thanks!
I know you're trying to make a deal for the vehicle but you should definitely edit out your info in the above post.
Scammers get on here and will run with that info.
Build up your post count so you can PM the seller with any details.
Reactions: Koozkooz
