1 - 20 of 20 Posts
Hello all,
I also have been through the mill on the hard down shift from 5th to 4th gear issue. A few times when hitting the resume for the cruise it felt like someone rear-ended us. Well to make a short story out of this. I took my Touareg to the VW dealership in Rochester MN. and after 2 weeks of going back and forth between my extended warranty company they decided to replace the transmission. I was driving home and the hard down shift from 5th to 4th gear was still there! It happened 3 times in just 3 miles, it also appeared the shifting didn't match the #'s shown as crisp as it should be. I called the dealership and broke the happy news to them. I'm taking the Touareg back in the shop the first part of April 2012. Does anyone have ant suggestions? Do you think the new transmission is also a lemon?? I have 78k miles, 2006 V8 Touareg, I bought it as a Certified VW vehilcle 3/2008 with 53K on it, at this point I feel VW should have a money back program with all these issues that I have been reading.
The normal fix for this is to drain the geearbox, replace the valve chest and refill.
Not a long job.
Did they really replace the whole gearbox?
Agree. I had valve body replaced and ll is fine. No new transmission needed. Extended warranty guys know that.
Thanks for your input, I was so upset when driving home, I WAS READY TO DUMP THIS RIG, but it has been such a cool vehicle until this problem showed up. The rep. and my repair slip indicated they replaced the transmission. So the valve body/valve chest is separate from the transmission? Here is the reply I got from the General Mgr. of the Dealership: I am sorry to hear about the issue you are experiencing with your Touareg. I will follow up with Kevin and stay involved with him. If I need to I will also have a VW Engineer come in. We will fix the issue for you. I really want to regain your confidence in a German vehicle. I am sorry that we were unable to resolve the issue the last time you were in.
Banned
Definitely the valve body, although I'm not surprised to hear they changed the transmission, as others have reported that their extended warranty company did the same as well. Talk about wasted money on their part for nothing. They are all idiots, all of them, but that is besides the point.
I too am curious why it is still exhibiting defective valve body symptoms, when everything should be brand new again.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
So the valve body/valve chest is separate from the transmission? .
No, far from it. The valve chest is inside the automatic gearbox so if they replaced the gearbox with a new one, then there should be a brand new valve chest inside it which is why it is puzzling that you still have the hard 5th to 4th change.
As we have said, the normal VW dealer repair for this well known fault is to drain the gearbox, take out the old valve chest and replace it with a new one before refillling the gearbox with new ATF fluid.
When your dealer is talking about replacing the transmission I cannot help but wonder if they have changed something else such as the stepper motor as my definition of the word "transmission" would include gearbox, drive shafts, stepper motor, differentials and axles but I'm English and the American definition differs as Wikipedia points out below in the second paragraph!
http://en.wikipedia.org/wiki/Transmission_(mechanics)
So you need to check with your dealer exactly which part of the car they replaced.
It had to be the transmission, according to the repair tag, it was listed as a itemized statement and the entire bill was $8500. Unless there are so many defective valve bodies the new one was another lemon. You would think by this being a 2006 they would have had updated parts to correct the engineering mistakes.
Discussion Starter #9
Interesting:
Today I went with my daughter to drop off her Jeep at a Chrysler dealer and just for the heck of it I asked one of the dealer managers about Touareg's in general. The subject came up about transmission issues, and his comment was that they had 3 Touareg's traded in from 2005-2007 that had the same problem as mine and their dealership took them to the auction. He indicated that they are a very nice vehicles but plastic parts were used in the valve bodies of these years and to make sure a "updated" valve body transmission was going to be installed. Not sure if this was a true FACT or just a line...anyone know if this is a true fact?
Discussion Starter #11
The VW Dealership replaced the transmission control module, and the saga continues..same problem as before, harsh downshift from 5th to 4th gear. They called in a VW repair expert from the VW company. I will update this when the next chapter is known.
Discussion Starter #12
Good news after further testing, changed the transmission fluid and filter to see if anything changed...NO CHANGE...then the VW expert loaded a new SW program and now the T-REG shifts like new, no issues and no charge.
I would be REALLY curious to see if they changed the coding on the tranny or what they did. You don't have a VAG-Com by any chance? Or near someone that does?
Very interesting to see if the hard shift down shift returns due to the well documented valve body replacement issue posted on here?
Don't forget that the silly buggers gave him a brand new gearbox to fix the 5th to 4th thump instead of a new valve chest which is the normal fix!
Discussion Starter #17
One thing that is different, the old transmission and SW program is that I had to be at a total stop before it shifted into 1st gear, now downshifts (smoothly) into 1st gear @ about 5 mph.
Thread revival:
What about hard shift from 4th to 5th.
What is the Software version of your transmission if you still have the car ?
Thread revival:
Hi im in chicago, i am a fanatic for bmw and vw cars. I been rebuilding a bunch of engines and transmission for this cars. I will say around 30 total never have an issue. And let me tell you that the vw touareg transmission is so easy to rebuilt
I charge 2500 for whole job including all new parts.
Dude in in France..... so good luck with that "quote". ;)
On the other hand, which trans code are you talking about in your quote above?
1 - 20 of 20 Posts
About this Discussion
10 Participants
TurboABA
Club Touareg Forum
Full Forum Listing
