I know this has been addressed alot but I haven't found my answer. I bought a 06 v6 with the xenon's. The error on the dash showed up for checked headlight range control module and stays lit up. I bought a new level sensor for the left front since my VAG by ross tech scanned and stated faulty left front sensor. I replaced it and still have the error. I did notice the plug is not staying tight so this may be the issue.
My questions are does anyone know where he wire from the sensor plugs into? bc i need to see about possibly replacing that plug/harness if thats the issue. Also i checked the passenger side front and didn't see a level sensor on that control arm. Should there be or is there only one on the driver side? My error im getting is for the driverside front headlight level sensor. And error in basic setting for adaptation light.
The rosstech errors are 00776 - level sensor, and 01539 - headlights not adjusted. Any help would be appreciated. I just want this dumb error to go off my screen.
Note that when i start my car, my headlights do calibrate and both of them move up, then down, then center and stay there.
Thanks in advanced.
Thanks in advanced.
