1 - 2 of 2 Posts
Hi,
I just picked up a 2006 V10. The check engine light is on and when I check it with a scan, I am getting P0471 Exhaust Pressure Sensor. Anyone who how to correct this? I just HOPE this does not involve separating the engine/transmission and the body.
Thanks,
Ben
Hi,
Thanks,
Ben
Ben
That seems like it has to do with the RH DPF sensor and maybe it is a lead up to an actual DPF issue.
Not a big problem to deal with the actual DPFs on the car but access to the sensors will be a bit difficult as they are mounted on the top of the transmission.
No the engine should not need to be removed for that issue.
regards
Drag
1 - 2 of 2 Posts
