1 - 20 of 20 Posts
2006 Touareg V8
153,xxx
Campanella White with Teak interior
Four Corner Adjustable Air Ride (no issues)
Heated Front and Rear Seats and Steering wheel
Center and Rear Locking Diffs
Four Zone Climate Control
Tow Package
Parktronic Park sensors
Reverse Camera
Keyless entry and Push button start
New battery
Recent Services done, Ft Crank Seal, Rear Main Seal, Both valve cover gaskets, Plugs, Transmission Service, Timing Belt, Water pump, all tensioners and rollers,
Prior to me at around 70-80k they replaced the front and rear diffs, driveshaft w bearing, alternator and compressor, rear hatch struts, most common issues with this generation touareg have been addressed and fixed.
Custom Spooling Tune
Euro Dash Bin
Cayenne Shifter mod
Joey Headlight mod
Painted Calipers
Cayenne S Swaybars
Carectare ft grill
Votex OEM spoiler
07+ smoked oem taillights
Will NOT come with the black wheels
Will come with 17" Canyon wheels with almost new Bridgestone Blizzaks
I have owned this since 2010, has been a great vehicle and I love it but I found something I want more so if I can sell it for close to what I want then Ill let it go, if not Ill just keep her and give her to my kids in a couple years. Everything works as it should, Has been very reliable and is very fun to drive. The only issues with it is it has some rust on the seem on the inner RR door. I tried to get VW to fix it and they said that its surface and they won't do anything with it, and the rear climate control has some peeling on the buttons which is common, I may fix this depending on selling price. Will send more pictures to interested parties.
233540
233539
Good evening. Can you show the interior pics and console area including gear box area
Sent from my HTC U11 using Tapatalk
Discussion Starter #20
I also just recently replaced the front brakes, so it has new brakes in the front and the rears are at about 70-80% I also had the outer tie rods replaced as they were worn as well. In the sale I will include a set of Front Upper and Lower Control arms as well.
1 - 20 of 20 Posts
