Kinda stumped a bit on this one and hope someone can help me out.
I just did a bit of maintenance and replaced most of the timing components on the engine. I replaced the timing belt,water pump tensioner, and all that stuff, when I was working on the engine I found that both of the tensioner gaskets were looking pretty bad so since I was in there I decided to replace them and since I was pulling them out and the engine has 230000km I decided to replace the actual chains and the slider pads as well. I did everything according to the manuals I downloaded from erWin. I triple checked everything and made sure it was all lined up properly. Got the engine put back together and started it up and it gave me a engine code (p0341) being that the code was not there previously I assumed that the camshaft position sensor was good and that the timing chain may have been off by one tooth. So I pulled it all apart checked it out and it was all good. Fired it up to try it again and I still had the code. So I swapped the cam position sensors to rule that out and there was still no change. Figured I better recheck the timing at this point so I put the crankshaft locking pin in and checked the alignment of the cams with the cam locking bar and it all lines up perfectly so that leaves pretty much the last timing being the alignment of the cam chain on bank 1. So I pulled the cam and the tensioner and adjusted it by one tooth and the engine ran with reduced power so obviously that was not the problem so I put it back and the problems still there. I counted out the 16 rollers according to the manual and I cannot get the timing triangles on the bearing caps to line up with the notch on the cam this is where I’m stuck (both chains are straight form the dealer so it’s not stretched or anything from being cheap). Still have the engine code and the engine has reduced power, I did a compression check to make sure the valves are good and not causing the power loss and compression is good. Other thing is that I had it at the dealer for some other work and they ran the codes for me and the service manager was kindly helping me out told that the code changed to a correlation code between the camshaft position sensors and the crankshaft position sensor.
