1 - 12 of 12 Posts
Good afternoon, new to this page. my wife has a 2006 and the blower motor has been working when it wants, and yesterday it finally stopped working. Should I start by replacing the resistor first? Thanks a lot for your help.
Try running in on HIGH. In that setting, the resistor array is not used and all of the electricity is sent to the motor. If it still doesn't work, then it's more likely the motor itself. How did it fail? Did it fail at all speeds, or just some speeds and then progress to all speeds? If it was progressive, then it "could" be the resistor array.
OTOH, if the array is easy to get to, it might be a less expensive place to start. I'm not sure if a VCDS scan will show you any trouble codes or not, but it's worth a shot.
I have tried on high and luck. it started to work intermittently and would occasionally work and then not work. Then it finally just stopped working. it almost sounded like i could hear a hum sound of sort but nothing. I can get to the resistor through the back of the glove box very easily. The resistor is $114 through the local parts store.
Thank you
Might want to try taking the motor out and seeing if it will work with direct 12V. Might be a PITA, but $114 is PRICEY for a part that may or may not be the culprit. If you pull the motor and test it, at least you know if it's good or not and know how to proceed from there. And you're only out you time, not any hard cash.
Is the blower motor easy to get to? Thanks
Not bad, but I would test in place with jumpers before pulling out. I have done two blowers, it is a back killer. Passenger side lower dash cover comes off, foot well light unplugs, foot well ventilation part pulls off and you can see the motor up behind the glove box. Plug is two pin and can be access w/o removal.
If you do remove, loosen right bottom bolt holding in glove box...it will cut you up otherwise and get in the way of removing the blower.
If you do remove blower. Watch very carefully how you fish it out. Hardest part is fishing it back in and bolting it up...one handed (unless you are super thin and can fit both arms under there.)
Failed blower are more common and make a distinct squeaky sound. Both mine went by being so sensitive to bumps and turns they would squeak and die. If none of this sounds like you, it likely isn't the blower. Sound...terrible squeaky...shrill bearing sounds are blower.
I just replaced the blower motor on my 2004. I bought original parts from the dealer. It was much more expensive than a replica, but its only money right. I first tested the wires to make sure the motor was getting electricity. If the wires were good then I figured it was the motor.
It is a pain to get the motor in and out but it can be done. A good light source is essential. it also helps to have a cooler or something next to the vehicle and level with the floorboard so your back isn't wrenched more than necessary. Also, I was confused because the noise the old one was making sounded like it was coming from under the steering wheel. The blower motor is located in my veh on the passenger side underneath the glove box.
Other than that, its basically taking one part out and putting the new one in. My new blower motor works like a dream. Good luck!!
Replaced my failing 2005 blower motor yesterday; the replacement was about $165 AutoZone fed-x delivered and relatively easy once positioned under the glove box.
tools needed: 5.5mm socket and extension
I was worried the glove box needed removing but not necessary; luckily several of my t20 glove box screws were not removable.
Be sure to replace the cabin air filter, while in the area.
1 - 12 of 12 Posts
