1 - 2 of 2 Posts
Took out fuel pumps now the center hose of the fuel pump keeps the fuel filter housing from being able to go back in place , the center pump hose is short and kinks real bad pushing up the filter housing, why? What is wrong ?
I'm thinking back a while so I might be mistaken but doesn't that hose connect to a short hose on the other end? Those should have a pretty decent acceptable bend radius which should let you stuff everything into the tank. Do you have any pictures of this that might help illustrate the problem you're having?
I found a lot of things cleared up when I got the pump locked into the tank. Things just fit more ideally.
1 - 2 of 2 Posts
