1 - 3 of 3 Posts
Purchased a set of Oro-Tek (OBE-011A) TPMS Sensors as they say to work with 2004 V6 Touareg.
shop put them into both the front wheels but they are still giving a fault after learning mode?
Do all 4 need to be replaced or does anyone know if this is not the correct model?
Reached out to Oro-Tek but so far no response.
You may have the wrong ones.
This is what I bought that works:
Oro-Tek Tire Pressure Monitor Sensor (TPMS) OBE-005.
I did check the OBE-011a on Amazon and fleebay and they both say it works with you Touareg.
Try the relearn I've had to do it more than once in the past.
Good luck.
1 - 3 of 3 Posts
