1 - 3 of 3 Posts
Hi just joined the club. I want to make my you are into a dependable vehicle but right now it has a lot of issues. My first priority is fixing the headlights from flickering. I switched the bulb to the other side and had the same issue so I'm hopping a new bulb will fix it.
Check the wiring loom of both lghts and replace crumbling wires. Mine were falling to pieces when I bought the treg. A used set of xenon lights solved it for me. This is a know issue.
Thanks for your help. Ill look for a used one but the new ones online are under $50 so i might do that. Can you verify the part number is d1s?
1 - 3 of 3 Posts
