Thursday,24,November,2022,12:18:02:39479
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVGPZ77L14D086653 License Plate: 11/24/22
Mileage: 231489 Repair Order:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 070 997 016 R HW: 028 101 172 9
Component and/or Version: V10 5,0L EDCG000AGMª2813
Software Coding: 0060575
Work Shop Code: WSC 22525 444 72946
VCID: 290FFC1725E08133B81-5160
8 Faults Found:
19793 - Engine-Engine Databus
P3337 - 000 - Implausible Message - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 000 - Open Circuit
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
(no units): 0.0
Bin. Bits: 11001001
18315 - Engine Databus
P1907 - 000 - ECU<->ECU Communications Fault
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 0.0 Nm
19794 - Control Circuit for Glow Plug Controller 1
P3338 - 000 - Electrical Malfunction
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
Temperature: 4.5°C
17909 - Fuel Pump Relay (J17)
P1501 - 000 - Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 0.0 Nm
16982 - Thermostat for Mapped Engine Cooling (F265)
P0598 - 000 - Short to Plus
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Temperature: 98.1°C
Temperature: 4.5°C
Bin. Bits: 00000011
16955 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Readiness: 1 6 0 0 0
Address 01: DTCs cleared
Address 31: Engine other Labels: None
Control Module Part Number: HW: 028 101 172 9
Software Coding:
Work Shop Code:
VCID: 55F780E75918F5D3CC9-5160
Address 01: 8 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
17848 - EGR Valve (N18)
P1440 - 000 - Open Circuit
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Mass Air / Rev.: 980.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Address 11: No Faults Found
or DTCs not supported by controller
or a communication error occurred
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Posting for Marcus
www.Ross-Tech.com
8 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
(no units): 0.0
Bin. Bits: 11001001
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 0.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
Temperature: 4.5°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 0.0 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Temperature: 98.1°C
Temperature: 4.5°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.86 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Software Coding:
Work Shop Code:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 189.6 Nm
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
Temperature: 9.0°C
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Bin. Bits: 00001110
(no units): 0.0
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 5.1 %
Voltage: 12.69 V
Temperature: 98.1°C
Temperature: 9.0°C
Bin. Bits: 00000011
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Bin. Bits: 1 01 0
Posting for Marcus
