1 - 4 of 4 Posts
1: (high priority problem)
Engine oil i dripping under my car.Seems to be from the right side of the engine. Engine is running fine. Is there any common faults that can cause this?
I have a 2004 touareg with the 2.5 tdi engine.
2:
Also got sporadic message brake assis fault workshop, this appears sometimes right after start up and it deactivates the ABS brakes. If I restart the engine, the fault disapears. Common problem?
3:
Running gear workshop and symbol of air suspensions. Pops ut a couple of times every week. Air suspensions is workig fine. Anything to be concerned about?
number 2 happens on mine but not so often usually when its cold and sitting around, goes after a re start
on 3 you may have a leak, look for a thread on air suspension leak
Air suspension? Pro & Con's - myTreg forums
i clean my air valves off and cover in grease every 2 months especially in the nordics with all the salt on the roads during winter
Thank you.. I'll try to apply some grease there. What type of grease are you using? And where is the valves located?
As a understand from reading other threads is that the fitting for the air hose on the damper have corrotion problems.
The right side front damper looks a lot newer than the left side, probably replaced by previous owner.
Any thick grease will do.
1 - 4 of 4 Posts
