This is a follow-up thread from http://www.clubtouareg.com/forums/f47/parting-out-silver-2004-v8-4-2-a-80032.html 2012 Touareg partout. I stopped selling parts for a couple years. Now I have pulled almost every part off the shell and have been trying to keep an inventory with each corresponding part number along with some pictures.
Although this list is not 100% finished, the only items left to add are random trim pieces that don’t matter too much. These are going to be added soon. Unless you’re looking for a rare part – if it’s not listed, I don’t have it.
Feel free to PM me or call/text me at (503) 766-9622
(503) 766-9622 Contact name is Bruno. I work night-shift and will only answer calls after noon. If you need to contact me before noon, use text message or e-mail.
I am based out of Portland, Oregon. I can ship through UPS to all states. International buyers will have to arrange their own shipping. I can deliver anywhere in the PDX area for gas $. I am also willing to drive 12+- hrs if it’s cheaper for the buyer.
6-speed Automatic Transmission includes 09D 300 036, 09D 321 105
7L6 823302 – Hood Hinge Passenger right side W/mounting hardware
A/C Compressor w/hardware 7L6 820 803 -
Acceleration Sensor 7L0 907 673 C -
Accelerator Pedal W/Electronic Module w/mounting hardware 7L0 723 507
Aerial Antenna Booster Amplifier 7L6 035 577 – (x2)
Air bag control module computer 3D0 909 601 D -
Air Outlet Assembly 7L6 819 703
Air Outlet Assembly 7L6 819 703 –
Air Suspension Pressure Lines 5x - Green, Yellow, Red, Blue, Purple
Alternator 07C 903 021 –
Amplifier 7L6 035 466 –
Anthracite Gray Grab handles 3D5 857 607 & 3D5 857 608 - (x3)
Auto Dim Rear View Mirror X18 -
Auto suspension air tank 7L0 616 202 A -
Automatic Transfer Box ECU 0AD 927 755 L
Bosch AC Servo Motor 0 132 801 320
0 132 801 320
0 132 801 320
0 132 801 320
0 132 801 320
0 132 801 320
0 132 801 320
0 132 801 320
Bosch Control, Headlight Range Adjustment 0 132 801 319
0 132 801 319
0 132 801 319
0 132 801 319
0 132 801 319
0 132 801 319
0 132 801 319
0 132 801 319
0 132 801 319
Bracket for Transfer Box & Gearbox ECUs -7L0 927 131 D -
Brake Booster Vacuum Pump 8E0 927 317 –
Center Console Compartment 7L6 863 284
Center Console Main Bracket 7L0 863 345 -
Chrome Inner Tail Gate Surround 706 863 459 -
Cover for instrument housing, left dash top cap 7L6 858 291 -
Dash Bare w/Glove box 7L6 858 904, 6L0 947 565 (LIGHT), 7L0 947 415 (light hook up)
Differential Switch 7L6 941 435 K –
Digital Climate Control Unit 7L6 907 044 F –
Door Panels
Driveshaft Propeller 7L0 521 102
Engine Control Module ECM 4D0 907 560 DA –
Engine Fuse Relay Box Unit 7L0 937 548
ESP Stability Control 7E0 907 652-
Floor Chrome Trim 7L0 853 656
Floor Chrome Trim 7L0 853 793
Front Dash Trim Molding 7L6 857 239 –
Front Dash Trim Molding 7L6 858 969
Front Impact Side Crash Sensorx2 7L0 909 606
Front Right & Left (Driver & Passenger) Seat Frame 7L0 881 678 D
Front Right Chrome Door Step Trim 7L0 853 655 –
Fuel Door Actuator includes: 7L0 862 165 (Black strap)1J0 810 773 B -
Fuel Door with Hinge & Hardware 7L6 809 805
Gearbox Transmission ECU Module 09D 927 750 N -
GPS Antenna 7L6 035 507 J -
Head Liner Roof Lining 7L6 867 502 -
includes 7L6 880 680, 7L6 867 506, 7L6 868 520, 7L6 867 501, 7L6 857 551, 7L6 947 292, 7L6 880 696, 7L6 880 616, 7L6 880 695
Headlight switch w/dimmer 7L6 858 903 T
Heated Seat Control Module 7L0 959 772 – (x2)
Heater Blower Control Regulator 7L0 907 521
Hood Hinge Driver left side W/mounting hardware 7L6 823301 –
Hood Release Cable & Assembly X19
Instrument Cluster Assembly 7L6 920 980 D
Interior Trim w/foam 7L6 867 247
Left & Right Curtain Airbag Driver Side Roof Airbag 7L6 880 741
Left Air Filter Box 7L6 128 601 –
Left Front B-Pillar Outer Black Chrome Trim 7L6 853 317 B -
Left Front B-Pillar Trim 7L6 867 239 Includes 7L0 868 311 A (seat belt adjuster), 7L6 819 209 B (air outlet) & 7L6 819 771 (electric cables for air outlet)
Left Front Driver Seat Memory Switch 7L6 959 766 B
Left Front Window Motor 3D1 959 793 B / 7L0 959 701 B
Left Rear B-Pillar 7L6 867 241
Left Rear Seat Belt Double Press Button Buckle w/hardware 7L0 857 822 B
Left Rear Window Motor 3D0 959 795 C / 7L0 959 703 B -
Left Side Door Floor Sill Strip Trim (where scuff plates/door entry step guards go) 7L0 853 370
Left Side Driver A-Pillar Trim 7L6 867 233
Left Side Mass Airflow Sensor 06A 906 461 G –
Left Side Satin Black Vent Cover 7L6 819 730 D
Luggage Compartment Trim 7L6 867 038
Main Center Console 7L6 863 243
Metal Frame Navigation
Parking/Emergency Brake Cover With Release & Cable includes 7L6 711 814 (parking/emergency brake release & cable) 7L6 858 903
Passenger Air Bag 7L0 880 202
Power Steering Fluid Reservoir 7L0 422 371 -
Pressure Unit Front/Air Tank 7L0 616 201 A
Radio Antenna Booster Module 7L6 035 530
Rear A/C Heating Blow Fan Complete includes 7L0 820 004:
7L0 907 521 (Heater A/C Control Module)
7L0 907 512 (Control motor for temperature regulating flap)
7L0 819 032 (Heater Core Exchanger)
7L0 819 358, 7L0 819 359, 7L0 820 361, 7L0 820 955 (Housing)
Rear Bumper Attachment Strips Includes 7L6 807 861 & 7L6 807 862 7L6 807 863 -
Rear Wheel Trim 7L6 863 819 & 7L6 863 820
Right Front B-Pillar Outer Black Chrome Trim 7L6 853 318 B -
Right Front B-Pillar Trim 7L6 867 240 includes 7L0 868 312 A (seat belt adjuster) & 7L6 819 210 B (air outlet)
Right Front Passenger Seat Memory Switch 7L6 959 765 B
Right Front Seat Belt
Right Rear B-Pillar 7L6 867 242
Right Rear Seat Belt - Includes: 7L0 868 312 (seat belt adjuster)
Right Rear Seat Belt Press Button Buckle w/hardware 7L0 857 821 B
Right Rear Seat Mounting Bracket Plate 7L0 885 342 E
Right Rear Window Motor 3D0 959 794 C / 7L0 959 704 B
Right Side A-Pillar Trim 7L6 867 234
Right Side Door Floor Sill Strip Trim (where scuff plates/door entry step guards go) - 7L0 853 370
Seat Mounting Bracket $507L0 886 221 F
Set of 2 Vacuum Reservoir Tank w/frame 7L6 131 541
Side Airbag Impact Crash Sensor Modules (x2)4B0 959 643
Side Trim Panel 7L0 863 528
Sun Roof Motor 8D0 959 591 C –
Sun Shade Visors
Tire Pressure Control Module 7L6 907 273
Tire Pressure Monitor Sensor TPMS (4x) 4D0 907 277
Torque Converter 50A150 03C13670
Towing Electronic Control Unit Memory Computer 7L0 959 933 C -
Transfer Case 09D 341 010
Transfer Case Shift Motor 0AD 341 601 –
Trunk Ceiling Interior Trim 7L6 867 617
Trunk Shelves/Side cover with foam 7L0 863 527
Unknown 7L0 339 255 – Passenger seat includes headrest includes 7L00 971 363 Wiring harness
Wiper Motor & Arm Linkage 7L0 955 119 & 7L0 955 023 –
Wiring harness with anti-theft sirens/horns
7L6 971 073, 7L6 951 185, 7L6 951 186, 6N0 951 221, 6N0 951 223
Call
Send SMS
Call from mobile
Add to Skype
You'll need Skype CreditFree via SkypeCall
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Door Panels
Sun Shade Visors
Call
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
Send SMS
Call from mobile
Add to Skype
