1 - 4 of 4 Posts
Smaller fan will run all the time if the A/C is on
Heaters? If the fans are set to OFF then the fan should switch off. You need to diagnose with VCDS when the fan is switched or not.
If it stays on, replace the fan. The controller is part of the fan.
1 - 4 of 4 Posts
