1 - 4 of 4 Posts
My '07 V10 is about to turn 150k. It's iin perfect condition and I would like to keep it this way. What do I need to look for at 150k, what needs to be changed or serviced?
It's a true gem and there will never be another. I only use it to tow our Airstream trailer. Not get groceries.
The turbo's were replaced about 45k ago. Cams are original, Front air suspension was replaced about 20k miles ago. It's been serviced by either by a knowledgeable VW dealer or a very good VW only shop. Only OEM parts have been used.
If a knowledgeable VW dealer or good indy shop works on it they should/will have the latest service guide. Your owners manual will also give a hint from what is required at the service guide at 100K or what ever the last one is. I have the same problem with mine. I have 250K km's but my service guide only goes to 200k km's! I use that as a basis and look a bit more carefully at areas associated with that component or item or area. VCDS is also your friend where it will pick up on electronic sensors, trends, etc. Sorry I could not be more exact.
1 - 4 of 4 Posts
