1 - 7 of 7 Posts
Hello.
I need to remove back door panel and I'm not sure how to do it. Car is covered by warranty and I don't want to break anything...
Can anybody help?
Mine came with w/o rear-view camera and GPS. I'm used with these features from my Passat so I don't want to give them up. I need to install/replace the door handle with one having a camera. Also need to tuck-in all the wiring.
They make wireless backup cameras. It may be helpful considering its a gigantic pain to remove the panel.
Sent from my XT1575 using Tapatalk
Thank you nickyt, but it doesn't help either.
I cannot use a retrofit, due to warranty. Even if the car has run out of original warranty, it came as certified with 24k/2y warranty. Therefore at this point I cannot do many changes. If available, I will gladly replace my RCD 550 with RNS850, but cannot find one.
So until warranty expires I will go with a cheap solution. Bought a camera, wireless trans/rec and a GPS w/ camera. All Chinese, $150.
Now I need to go under tailgate panel, to install them.
Found this but doesn't help too much. My panel is different.
1 - 7 of 7 Posts
