1 - 14 of 14 Posts
Hoi there, just got a Touareg with 85k on the ODO. Wondering if theres any upgraded A-Arm and sway bar sets for this? Its really sloppy over bumpy roads.
Or perhaps theres a parts bill for new parts? The shocks feel fine.
thanks
The bushings are hollow. Solid bushings should last longer.
DIY Dan via Youtube said:
Published on Oct 28, 2018
The upper and lower control arms on my Porsche Cayenne are shot after only 75k miles and are in need of replacement. Since I wasn't happy with the longevity of the factory units, I decided to go with a set of aftermarket control arms from Mevotech, who claims their control arms are "overbuilt". Are they? You be the judge...
All Mevotech supreme parts have a part number that begins with "MS". All of the part numbers starting with "GS" are their cheaper economy parts that aren't "overbuilt". You can get the exact parts that I used at the links below:
Upper Control Arms: https://amzn.to/2yANv5Z
Left Lower Control Arm: https://amzn.to/2CKWKDH
Right Lower Control Arm: https://amzn.to/2Avx3FN
Stabilizer End Links: https://amzn.to/2OWNLqa
Diverter Valves: https://amzn.to/2JmedUj
Ball Joint Removal Tools: https://amzn.to/2ObpYNW
Disclaimer:
Due to factors beyond the control of DIYDan, I cannot guarantee against improper use or unauthorized modifications of this information. DIYDan assumes no liability for property damage or injury incurred as a result of any of the information contained in this video. Use this information at your own risk!!!
I'd be careful who's parts you use. Also I wonder why Porsche used a hollow bushing in the rear. Perhaps they did this on purpose for suspension tuning reasons rather then planned obsolescence.
What are the symptoms of bad control arm bushings on a T3?
I agree. Years ago I was in a group where members would upgrade their worn suspension with racier mods, but it didn't always pan out for the best. If your bushings are worn, replacing them with OE without 80K miles on them is already going to be firmer than you're used to. Going from worn out bushings to solid bushings is going to transmit a substantial amount of road feedback into the vehicle. You might like that but it's worth considering.
Discussion Starter #8
The symptoms are the car hops to the side when going over manholes and bumps. Same road I drive everyday in my Volvo V70R and Dodge Dually.
Hmm, Says it doesnt fit a '13 when I use Amazons fit guide
well, those parts are for the porsche, so it makes since amazon would say they dont fir(even tho they probably do fit, they are Porsche #s not vw #s.
As always, verify
Discussion Starter #11
Owl do you have air suspension or coil suspension?
Do any of the US. 7p have air? I got scared after I picked this car up that it would have air suspension. But I don't see any of the indications that it does. What would I look for? If it has air I'm selling it
Yea right after I typed that I figured you were probably US and edited my post with the sway recommendation. :nerd:
There are lots of people who still wished they could get air suspension whilst the Touareg was still being sold in the US!
If you had air consider yourself lucky!!
Discussion Starter #14
Well I guess someone could order it. Might as well get two of them, you're gonna need it.
I won't own another air ride car in my lifetime.
1 - 14 of 14 Posts
