Any news regarding this? My 2016 VR6 had this issue when I first bought it as a CPO, and then it miraculously went away. At my last service they recommended 90k service(plugs and filters) and the issue came back! lol, what a nightmare.
I agree 100%, The old adage "If it ain't broke a the moment don't fix it" is so true. Just keep a copy of the code for future reference. This was my intent with my posting.Thanks Cad_Man. Will show your info to the dealer. However, I need to be careful because my car is bearable right now and I’m not sure I want to tempt fate by having anything done at this point. My car was in the dealer 8 times for a total of 100 days for this issue so I don’t want to risk any repeat. However, if the issue resurfaces I will have the update ASAP! Thanks again for the suggestion.
I call Bullshit on the air filter not being properly sealed... It is so easy to get water in the Intake pipe, especially if you use touchless car wash or high pressure hose at hand car wash DIY bays. They don't want to admit to the design flaw on the facelift versions of the Touareg. Take your front grill off pour a cup of water down the hood when it gets to the headlight assembly water is directed straight into the Intake pipe! With grill off you can see how there is nothing to stop this from happening. You think they would come up with a deflector plate of some kind to block this from happening.I just brought my 2017 Touareg in for the software update in Winnipeg and noticed the same thing Cad_Man mentioned; higher rpms for first 30 or so seconds. I was experiencing misfire on cold start for cylinders 2,4,6. I also checked the air filter earlier in the process and there was sign of water damage at the bottom, but they told me that was from it not be properly sealed. They replaced it, so I'll keep an eye on that. I haven't had the chance to test the cold weather start yet, once it cools down a bit I'll be able to see if it was successful.
Thanks for that tip, I'll give it a go. I use the wand wash every other week so that could be itI call Bullshit on the air filter not being properly sealed... It is so easy to get water in the Intake pipe, especially if you use touchless car wash or high pressure hose at hand car wash DIY bays. They don't want to admit to the design flaw on the facelift versions of the Touareg. Take your front grill off pour a cup of water down the hood when it gets to the headlight assembly water is directed straight into the Intake pipe! With grill off you can see how there is nothing to stop this from happening. You think they would come up with a deflector plate of some kind to block this from happening.
I bought some of this weather strip to put on top of Headlight under hood to redirect water away from grill.
It should do the trick, I am waiting for a warmer day to stick it on as temps have been a bit cold lately.
