I decided to pull some info off my trans since I'm toying with the idea of doing fluid changes on the drivetrain, and I was curious to see how it's dealing with temps. I'm also about to do some landscaping this weekend and have an estimated 3k worth of river rock which I'll be towing for about 1.5hrs at freeway speeds and am curious to see how much this activity will stress the system.
Vehicle is my bone stock '14 TDI, neutered, original fluids, ~96K (miles) on clock.
Here's a log from my daily work commute, with a touch of hooliganism added in for experimental purposes.
Log #580532
Also, came across some interesting MVBs which would be good to know about when you're shopping for a vehicle in order to determine how it has lived up to that point.
Log #580532
Address 02: Auto Trans (0C8 927 750 CF) said:21:22:01
IDE06881-ENG99951 Max. transmission fluid temperature over lifetime-Lifetime ATF Sensor Max Value 98 °C
IDE06883-ENG99296 Max. transmission fluid temp. model value over lifetime-Lifetime Maximum Temperature Model 133 °C
IDE80036-ENG103596 Analysis 36-Max vehicle speed 153 km/h
IDE80041-ENG101805 Analysis 41-DrivingRecorder inRpm Area (3000 <=inRpm> 5000) 1434.8 s
IDE80041-ENG99539 Analysis 41-DrivingRecorder inRpm Area (inRpm <3000 [rpm]) 10295075.0 s
