1 - 4 of 4 Posts
Shift solenoid A valve 1 N88 is located in valve body of transmission. You can test to see if it's bad.
Test prerequisites-
Respective fuses in fuse box( instrument panel, right) must be ok. Selector lever must be in P position. Ground (GND)
Connections to transmission must be ok. Ignition switched off.
Test sequence-
Disconnect 14 pin harness connector to solenoid valves. Check resistance of pin 1 (solenoid valve 1 N88) ground transmission ( Specified value 10.0-16.0 ohms). If specified value is not obtained replace respective solenoid valve.
This info is from my Bently manual, hope it helps
1 - 4 of 4 Posts
