That’s correct. 3.6 has only one pump.
1 - Fuel tank filler neck
q With connection for earth cable to body
q Check for secure seating.
2 - To activated charcoal filter.
3 - Fuel tank
q When removing, support using engine and gearbox jack -V.A.G 1383 A-.
q Removing and installing → Chapter.
q Emptying fuel tank → Chapter.
4 - Fuel filter
q Assembly overview - fuel filter → Chapter.
q Always renew flange seal
q Renewing → Chapter.
5 - Locking ring, 110 Nm
q Remove and install using wrench -T10202-.
6 - Suction-jet pump
q Clipped into bottom of tank.
7 - Fuel gauge sender 2 -G169-
q Left side.
q Flat, square float
8 - Suction-jet pump
9 - Protective cover
q For bottom of fuel tank.
10 - Securing strap
q Note installation position.
11 - 20 Nm + 1/4 turn (90°) further
12 - Protective cover
q For top of fuel tank
13 - Fuel delivery unit
q Checking fuel pump:
Vehicles with one-piece intake manifold → Chapter.
Vehicles with two-piece intake manifold → Chapter
14 - Fuel gauge sender -G-
q Right side.
q Round, ball float
15 - Flange
q Right side.
q With pressure limiting valve
q Individual parts → Fig.
q Note installation position on fuel tank → Fig..
16 - Breather line
17 - Expansion tank
18 - Gravity valve
19 - To pressure retention valve
