1 - 6 of 6 Posts
Hey guys new here to the treg scene i just grabbed one the other day. Basically i knew it had issues so here we are im trying to diagnose its no starting issue.
2005 3.2 V6 165k miles
Going to grab vcds and scan it up but heres some back story maybe someone can give advice were to look first
Apparently cut off while driving one day on highway been stuck in the driveway apparently no major knocking sounds or leaks. prior owner frequently ran on E and had a mass air flow & o2 sensor CEL code prior to no start problem but ran fine No codes founds using a basic OB2.
Replaced battery still wont start.
Attempts to crank when battery is charged but i believe there is a current draw somewere too since its dying quickly ...
It cranks but very weakly and cuts out quickly + electronics seem to dim out a bit and a bunch of other faults i cant read pop up. Tried smackin on the fuel pump metal covers while cranking that did not help nor did i hear it "prime" when putting key in on.
Doing some research i hear the fuel pumps, alternator, cam position sensors, engine speed sensor could cause this no start issue but im a lost cause without some real scans so il update this asap with voltage and fuse checks. nd get vcds working hopefully
P.S. Best oil grade?? Brand?
Start with the basics.
An engine needs 3 things to start.
Fuel
Air\Compression
Spark
Do you have all those?
VCDS-Lite Version: Release 1.2
Thursday, 02 May 2019, 11:37:26:49257
Chassis Type: 7L - VW Touareg
Scan:
01,02,03,05,06,08,09,11,13,15,16,17,18,19,1C,22,29,32,34,36,37,39,3C,46,47,55,56,57,64,65,68,69,6C,6
D,6E,75,76,77
Address 01: Engine Labels: 022-906-032-AXK.LBL
Controller: 022 906 032 FT
Component: MOTRONIC ME7.1.1G 6618
Coding: 0000133
Shop #: WSC 08091
VCID: 62B7E9E2FD57
2 Faults Found:
29077 - Implausible Data Received from Cruise Control Module
U0405 - 002 - Lower Limit Exceeded - Intermittent
29074 - Invalid Data Received from Transmission Control Module
U0402 - 008 - Implausible Signal - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: None
Controller: 09D 927 750 BA
Component: AL 750 6A 0556
Coding: 0004153
Shop #: WSC 31414
VCID: 6EAF8DD2398F
No fault code found.
Address 03: ABS Brakes Labels: None
Controller: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
Shop #: WSC 31414
VCID: 3D0D7A9E2469
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 05: Acc/Start Auth. Labels: None
Controller: 3D0 909 135 P
Component: Kessy 6610
Coding: 0000232
Shop #: WSC 31414
VCID: 321759A2ED37
2 Faults Found:
00087 - Terminal 30 for Starting Relevant Consumers
009 - Open or Short to Ground
00668 - Supply Voltage Terminal 30
Address 08: Auto HVAC Labels: None
Controller: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0020030
Shop #: WSC 01814
VCID: 351D62BE1C59
2 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Address 09: Cent. Elect. Labels: None
Controller: 7L6 937 049 K
Component: 2703
Coding: 0101599
Shop #: WSC 31414
VCID: 44FB0F7A4783
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
01498 - Bulb for Parking Lamps; Right (M3)
00907 - Intervention load Management
000 - -
Address 16: Steering wheel Labels: 7L6-953-549.LBL
Controller: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000031
Shop #: WSC 31414
VCID: 40F3036A539B
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: None
Controller: 7L6 920 970 L
Component: KOMBIINSTRUMENT RB8 1835
Coding: 0007231
Shop #: WSC 08091
VCID: 40F3036A539B
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 31414
VCID: F09313AAA3BB
Address 1C: Level Sensing Labels: 7L6-919-879.LBL
Controller: 7L6 919 879
Component: JCI PathPoint 1700
Coding: 0000000
Shop #: WSC 00000
VCID: 047BCF7A0703
1 Fault Found:
00926 - Terminal 30
Address 22: AWD Labels: None
Controller: 0AD 927 755 BE
Component: TRANSFERCASE 0122
Coding: 0000000
Shop #: WSC 00000
VCID: 7F7140966EE5
1 Fault Found:
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Address 29: Left Light Labels: None
Controller: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000002
Shop #: WSC 31414
VCID: E6BF75F2917F
3 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
01344 - HID (Xenon) Headlight
012 - Electrical Fault in Circuit - Intermittent
00774 - Level Control System Sensor; Left Rear (G76)
Address 39: Right Light Labels: None
Controller: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000002
Shop #: WSC 31414
VCID: E7A178F69675
2 Faults Found:
Address 46: Central Conv. Labels: 7L0-959-933.LBL
Controller: 7L0 959 933 E
Component: GY HSG 0201
Coding: 0000085
Shop #: WSC 08091
VCID: 3E0F7D92296F
9 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
01516 - Terminal 30; Left
00926 - Terminal 30
01134 - Alarm Horn (H12)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J398)
Address 47: Sound System Labels: None
Controller: 7L6 035 456
Component: 08K Audioverst. 0105
Coding: 0000000
Shop #: WSC 00000
VCID: F09313AAA3BB
6 Faults Found:
00419 - Left Front DSP Midrange Speaker (R103)
007 - Short to Ground - Intermittent
00870 - Bass Speaker Front Left (R21)
006 - Short to Plus - Intermittent
00420 - Right Front DSP Midrange Speaker (R104)
Address 56: Radio Labels: None
Controller: 7L6 035 180
Component: Radio DE2 0009
Coding: 0001035
Shop #: WSC 31414
VCID: EAA701C28567
1 Fault Found:
Address 68: Wiper Electr. Labels: None
Controller: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414
VCID: 370168B60655
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.LBL
Controller: 7L6 919 044 K
Component: DACHDISPLAY 0538
Coding: 0000000
Shop #: WSC 31414
VCID: 3FF100962E65
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
End --------------------------------------------------------------------------------------------------
1 - 6 of 6 Posts
