1 - 2 of 2 Posts
So I have an '05 and run this outdated nav DVD.
I read that the 7B is the last update but VW sells this 8B for the 2006 and up and I wonder if anyone has tried it on the '05 nav system? Probably wishful thinking :(
The pic they use for the 8B is actually a 7B.
Then the question is where to get the 7B?
In the end not a big deal, I do have a Garmin and CoPilot on the iPhone, but if I can throw in a much updated DVD I'd consider it.
8)
The 8b disc will work. I have an 05 Touareg with the DVD navigation and was running the 2b disc. I was able to get the 8b disc installed only after the dealer did a firmware update. I think they charged $50, but it's well worth it. I also have an 08 Passat and the 8b disc loaded just fine. There must be some difference in the systems, but the 8b will definitely work in the 05. Good luck!
1 - 2 of 2 Posts
