1 - 2 of 2 Posts
hello. im a new member and not sure if im doing this right but i have a 05 touareg 3.2 gas that wont start unless its at least half throttle. and when it does start it runs so rough and if i let off the gas it will die. any ideas. just stared like over night:confused:
Hello
Sorry to hear your trouble.
It would be good if you could scan for codes using VCDS or similar.
What's the service history like? Have you had coils & plugs replaced at all? How many miles/kms?
I am suspecting fuel lines (air) , fuel pumps (no pressure) , air flow sensor (between air filter and throttle body) , PCV valve.
You might try disconnecting the air flow sensor and seeing if it will run in a default mode.
Ben.
1 - 2 of 2 Posts
