so upon start up yesterday my touareg immediately was running very rough with massive miss fire so I ran the codes... with a cheap auto zone scanner
it says bank one camshaft sensor problem and cylinders 1,2,3,4 are misfiring
any thoughts on this?
can the camshaft sensor cause this? if so is it likely to have caused damage to the engine?
I will be doing a compression test tomorrow am I hope its not a cam or timing issue.. the timing belt only has 40k miles on it and was installed by the dealer...
Matt
Matt
