1 - 13 of 13 Posts
FS air ride 2004 Black v8 broken
Located in fulton NY 13069
i don't have the facilities nor will to part it out.
3k or trades for trailer, snowmobile, outdoor equipment, atv, utv, pickup
or try me, im pretty open and need a lot of stuff. renovating 3 houses at the moment.
DOES NOT HAVE PARKING SENSORS, that button is hooked to the LED bar.
2004
AXQ. V8
38819
The bad
After doing round 3 of maintenance and driving from FL to NY aug 2017, The Touareg was here 3 months and developed low oil pressure and I’ve not been able to fix it. It’s not leaking out and oil level isn’t low. All electric assemblies work, Everything. My vehicle needs have changed and I need a pickup truck and trailer so I’m not motivated to fix this.
I printed all of the receipts I have, along with some originals if you want records.
The good
Owners manual with off-road CD.
181k Black
anthracite leather
bi xenon
4 corner air
rear dif lock
11 speaker audio, aftermarket nav
Factory hitch and module w hitch adapter
23 inch led bar
Genuine Porsche wheels, replica center caps x4
Oem vw wheels x4
Air hose for using onboard compressor
Inflatable spare
Heated seats front
Sunroof
Roof rack with keys
I had planned to keep this another few years so in the last 5k in Florida while I still had a garage I have done the following as part of 175k maintenance.
Because of peeling
New steering wheel controls x2
New A/C unit
New headlight switch
Timing belt pp297LK3 10-3-16
Water pump
Thermostat
Tensioner
H7 bulbs
Knock sensor x1 wasn’t bad but while intake manifold was off.
Hids
4 oxygen sensors
Coolant
Valve cover gaskets x2
Cam chain tensioner and gasket x2
Wiper blades x2
Camshaft position sensors x2
Cam plug seals x2
Coolant temp sensors x2
Pcv valve
Fuel filter
Intake manifold arms and flaps x2
Mafs x2
Air filters x2
Camshaft seals x4
Ignition coils x8
Spark plugs x8
Check valve for brake pump
Brake pump tubing
Battery 1-29-17
Overall since I’ve had it
Brakes
rotors second set by me.
Brake wear sensors
Transfer case replaced 2012/13 new old stock not rebuilt.
any other picture requests ill get them as quick as i can.
Discussion Starter · #10 ·
don't forget about trades people
ill trade for almost anything that is not a car. it has to fit on a moving truck.
tools, shopsmith accessories, Klipsch speakers, apple products, pc laptop, motorcycle running or not, quads running or not, roland instruments (drums or keyboard), tow dolly, or small car trailer just not a car or truck.
1 - 13 of 13 Posts
