1 - 6 of 6 Posts
2008 Touareg V8
My 2008 Touareg V8) started having a problem. The fan would run at full blast and stays on even after the car is off. After reading thread, its has to do with the temperature sensor. Where is the location of the coolant temperature sensor? Location of both sensors?
I had that sensor fail on my wife's V6 Tdi with the same symptoms
It is located on the RHS of the engine at the back just underneath the turbocharger inlet pipe.
You will need to remove this short connector pipe from the turbo to access the sensor and connector
I presume you have a V6 tdi and your RHD as you give no basic in your profile at all !
regards
Drag
1 - 6 of 6 Posts
