1 - 4 of 4 Posts
Hi everyone!
My '04 V10 (231k km) with air suspension has been throwing this code intermittently for the past six months:
01772 - G291 - Implausible signal
I've put many km's on the car in the meantime and haven't noticed any real issue...
One or twice the car seemed to run a little high and sometimes it takes a while for the car to be fully raised (when turning the ride height dial). Also, the compressor can sometimes take a little while to build up pressure when I'm filling tires.
I checked the forum - information overload - and cannot find any "resolved" posts.
Any advice?
Best,
VD-CH
replace the pump's cylinder head and piston ring.
Replaced the pump cylinder head and piston ring yesterday. Stupidly, I took out the air hoses from the compressor before working and the car was on jack stands (only front axle) so the rear suspension was down completely and when I lowered the car from the stands it was uneven.
Started/turned the engine off a couple of times and cycled it through high/low comfort/sport and it seems to be reasonably level again (front a little bit lower than the back, less than 3cm difference). Also not throwing any errors messages anymore...
Thanks for everyone's input, especially @4ePikanini
1 - 4 of 4 Posts
