Just wondered if anyone recommends fuel additives for the new diesel motor. Years ago I had a diesel truck and there was a fuel additive (redline?) that someone recommended to keep the fuel "happy".
The 2014 "new" motor isn't "new"... It's the same TDI as 2013 and essentially not too different from all other versions of the 6 cylinder TDI.I didn't see any posts that specifically talked about the new motor.
That part is very true. And the data that you can find, is not really comparable from one product to another, so it's hard to tell what really works and what doesn't.You'll find a lot of opinions and anecdotal comments about additives. Very little data. ...
I've never experienced gelling and I hope I never do. Luckily my Treg is garaged and freezing temps are mostly not an issue.That part is very true. And the data that you can find, is not really comparable from one product to another, so it's hard to tell what really works and what doesn't. One thing, howeer, that I think is probably more important than additives, is making sure that you have something in your tank when it gets cold so that you don't gel. This is the voice of experience after experiencing gelling for the first time last winter. No fun. No fun at all... I don't use additives at any other time of year. Just when it's cold. YMMV...
Time to get some winter fuel in the tank even if garaged. Just driving in the cold weather can get your fuel to gel, depending on the temp. It can create big problems if that happens with the adblue system. This is why there is winter diesel and summer diesel.I've never experienced gelling and I hope I never do. Luckily my Treg is garaged and freezing temps are mostly not an issue.
When I'm filling the tank I add Stanadyne first and I always tell the attendant "it probably doesn't do any good but it makes me feel better" which is usually good for a laugh (no self serve in Oregon). Anyway I'm confident it doesn't do any harm and it might actually do some good.
For a novice like me on these additives, what is the difference between Opti-Lube vs Syanadyne vs Ceratec?
Understand they all improve many things in the engine, but is there one better than the other other?
For my Aussie friends, do you know if any of these additives impact standard or extended warranty?
