Hi Guys, I appreciate the input!
1) Does zero deductible warranty not cover diagnosis time?
I have my V10 TDI at my local dealer today under a VW Real Driver Platinum warranty 7/100k miles with zero deductible. They called Langhorn VW where the warranty was purchased by myself a few years ago. My dealer called me and wants to charge me diagnosis time of 2 hours at $125 per hour. If that is how it is then so be it, I will pay it regardless. I just thought that a zero deductible warranty covers everything from diagnosis to parts, if of course they find a problem. Presumably there should be a charge to the vehicle owner if there is nothing wrong with the vehicle....just my thought process, but I have no idea
2) Glow plug light comes on and goes off intermittently. Usually comes on when weather dips below around 60F. I read that there was a recall on these glow plugs. Could I request of them to change them out if it is true that there was a recall? All this while my V10 is currently at the dealer.
3) I Vag-commed my V10 (obviously didn't clear the codes) prior to making the appointment with the dealer for today as the engine light was on. It said something about passenger side bank 2 exhaust temperature sensor. When I looked up parts I came up with 2 different length sensors. How do I know which is correct? Same thing with fuel filters.....80% plus of 2006 V10's have two fuel filters and mine happens to be the one that has only one bigger filter. How did this happen?
4) Big reason for todays dealer visit is a drive shaft vibration under acceleration. Mine just turned 50k miles and I have read that they go around now to 80k miles. Presumably they will order the whole new 2 piece shaft. I have read that there are aftermarket driveshaft support bearings. Will that reduce the chances of the new driveshaft dying after another 50k miles?
5) I already replaced 2 turbos at 38k miles. When do I expect those to blow up again....76k?
I love this car, but dammmn
The warranty question is the big one I would like answered, the rest is just conversation input. I thought everyone should be aware of this warranty issue.
James
James
