How hot are the heated seats supposed to get at the highest Knob setting? Mine seem like they're producing the heat of setting #1 when they are on #5. Anyone?
Mine heat up fine and fast about 1 min to warm and 2 for HOT.They get hotter once you sit on them, for the obvious reasons that for one, your weight is squeezing all the air out of the foam, which acts as insulation (the air). Second, your butt is acting as insulator to trap the heat.
I don't believe the seats heating elements are activated when you sit on them, unless there was a change 2006+. I've often switched on the passenger side seat heating element, so that the seat will be pre-heated, before my passenger enters the vehicle.
I always pamper my passengers![]()
I'm confused, didn't you write as your thread opening post, that setting #1 was like #5?Mine are actually fine.
To clarify, mine are fine now that I understand they need to be left on for a while to warm up to full hear when set to 5. Mine were not heating up for me for some reason, but after my battery issue it's been fine.I'm confused, didn't you write as your thread opening post, that setting #1 was like #5?
