Greetings from a third-time TDI and first-time Touareg owner, specifically a 2016 TDI Lux 4 door wagon/sport utility with all wheel drive. Here in Club Touareg there are a lot of knowledgeable Touareg owners with a lot of experience with Touareg towing. I know the subject has pretty much been beat to death in here but I'd like to revisit it with three specific questions. First some background:
Currently I tow my travel trailer behind a Super Duty 7.3 Powerstroke. My travel trailer is single axle, 23' long, 8' wide, 10' tall, and has electric brakes. Its dry hitch weight is 300 lbs, dry weight of 3200 lbs, and GVW of 4600 lbs. For towing with my truck there is no need for a weight distribution system. All that said, I now want to tow the travel trailer behind my Touareg.
1. Do I need a weight distributing hitch? Or obey the technical requirements on page 180 of the Touareg owner's manual which states "Never install a weight-distributing or load equalizing trailer hitch on your vehicle. The vehicle is not designed for this kind of trailer hitch."
2. The Touareg is fitted for towing; e.g., it has a hitch and 7 pin trailer plug. However, due to the pristine condition of the hitch, I think its previous owner never towed anything. There isn't even a scuff mark inside it. So I presume I need to get under the dash to complete the wiring and installation for a brake controller. Any recommendations for a brake controller? Or can I simply re-adjust the settings and use the Tekonsha Prodigy P3 controller from the truck?
3. Any recommendations for towing mirrors for a 2016 Touareg?
Questions? Comments? Concerns? Thanks in advance for any advice you can give me.
