Here's the newest 2023 available map update for the RNS850 Europe Region:
mega.nz
1. You can't find this archive anywhere in the internet, cause it's made by myself. It's a simple Audi MMI3GP conversion.
2. Databases are 100% identical with VW standard. There is no ingeration in originality of the databases.
3. This package is CHECKED, I've installed it to my RNS850 and it runs flawlessly.
4. Don't use Green Menu, You need to use User Defined method selecting Y for all available options (except for Bootloaders) .
5. Special destinations search section (POI) is from older 6.32.1. It works offline.
6. Don't ask how to upload it into Your RNS. There's answer for that in the internet.
7. If Your map won't work after 3-4 minutes after the update don't panic. It means You need to activate it. This scripts slays process which checks if the maps are activated. Here, it will make Your maps work:
mega.nz
or unblocker from DrGER:
github.com
8. Please RESHARE. If You've downloaded it, upload it to any possible server to share with other people. Even You can post alternative links in here. I've seen many offers for upgrading this version for money, please don't do this.
9. All the functions like TMC and others work.
10. If someone is successful with updating, please don't be shy and let us know.
11. This map works with P0824 firmware. I have no experience for version below them.
12. If You don't know what to do please ask for help. No shame in it, but don't be lazy.
13. Don't use MacOS to extract or upload Your files onto SD Card!
14. When You'll have 03623 or 03276 errors in 5F module after the update I can help fix them (one of them requires VCDS).
This is how to solve one error:
This is how to solve the other:
mega.nz
15. Use solid SD Card, not a microSD with adapter.
16. Here's P0824 firmware (for ROW - Rest of World and ECE - Europe only):
mega.nz
P.S. Feel free to ask me any questions (except for stupid ones).
New look:
Installation successful:
Here is POI offline fix:
mega.nz
1. Please use FAT32 SD Card
2. Start upload process
3. Choose 6.36.0 ECE
4. Choose 'User defined' mode
5. Tick LIT databases from 1 to 5 (status changed to Y)
6. Tick PKG (status changed to Y)
7. Press forward... proceed
This fix is ONLY for my 6.36.0 maps with the Audi newest POIs. If someone will upload it to another combination of his files the NAV system will STOP working. This patch is tested, no guessing in here. After an update selecting POI categories and searching for them in the offline mode will be enabled:
19 GB file on MEGA
1.9 MB file on MEGA
MMI3G-Navdb-Unblocker/navunblocker-230308.zip at main · DrGER2/MMI3G-Navdb-Unblocker
Patch MMI3G/3GP systems to unblock access to an updated navigation database. - DrGER2/MMI3G-Navdb-Unblocker
1.14 MB file on MEGA
684.39 MB file on MEGA
New look:
4.23 GB file on MEGA
