41 - 60 of 60 Posts
Discussion starter · #41 ·
Thanks !
I hope it is completly "fixed".
1. The DPF delete included both upstream and down stream coolers and associated hdwe.(pic)
2. If I understand your question, the Malone Tune/RevZilla removed the EGR via the Stage II tune.
Thanks !
View attachment 264288 View attachment 264288
I'm not seeing a DPF laying in that pile anywhere...
If you had a deleted stage II tune you wouldn't have an EGR light on the dash.
Oops my mistake DPF pipe is not in the pic.
The DPF exhaust pipe section along with the cat section were replaced with the Rawtech pipes when the Malone stage two tune was done around two years ago.
Perfect!
So you got a re-tune from Malone to accommodate the deletes as well?
Discussion starter · #48 ·
yes sir! malone tune and rawtek dpf /cat delete pipes were the first "long term plan" updates I did,and thanks to you guys and sustdi's hdwe prompting me remove the egr cooler,I believe the preventative maintenance is complete.
.My current issue (which I'll live with) is that the flex section of now gutted downtube pipe(from the turbo) is leaking exhaust fumeswhen stationary.Its not an issue when moving since there is no backpressure in the exhaust is now.I guess the options are ffind a good used cat downtube to gut again or bite the bullett and pick up darksides ss downtube pipe.I doubt tha an exhaust wrap would work in that section.
Even though I dont tow the track car anymore, I have gotten very attached to the beast,and so has our boxer, he thinks he owns it.
Savage , I'll run another scan (AND WRAP IT) JUST TO KEEP YOU HAPPY, WHICH IS MY SECONDARY OBJECTIVE IN ADDITION TO TAKIN CARE OF THe Treg.
Wait, what does your "egr" light look like on the dash............ send a picture and attach vagcom codes.
Discussion starter · #51 ·
I reflashed the malone stage tune ,hoping to clear the little yellow engine outilne on the dash display, but no cigar.
Hv attached the data log from this am,egr codes in spades.Both sensors (electrical connectors)are of course open now,and ziptied in the engine bay just in front of the oil cooler.(pic attached)
Dawg. If you are pulling EGR codes, you have the wrong tuning. Contact Malone.
So you over-promise and under-deliver.... So much for my happiness 😢
He's clearly not getting my hints so you have to throw a dog a bone once in a while
Bruh, why you trying to give credit for my meme to someone else? I'm devastated 😢
Just figured I'd let you know that "Your Meme" has been floating around the net for a few years and is being used by different people with different wording that they changed to suit their needs.
Might want to contact everyone and get some of those residuals. :ROFLMAO:
41 - 60 of 60 Posts
